inferno
I Different M 3.1?
inferno
ive found a 2litre xm lux in the scrappy, it has all the same sensors and wiring as the bx gti, but also has a landa senser, and the throttly bodie is a larger twin butterfly webber. will this work on the gti's the same as the bx gti looms? or what about on a 16v? ill get ecu numbers later
Pug_101
Is it AFM or MAP system?
inferno
sorry tittle f*** up... its afmless... using a map senser...
Could be either MP3.2 or Magnet Marelli.
Any should work but it'll need mapping to be ideal unless you use the exact same engine as originally powered by it.
Graham.
