Powers
Mi16 Problem
Powers
My Mi16 has recently developed this fault that makes it un-driveable!
The car starts without any problems when cold.
Idles perfectly around 900 rev/min.
I can blip the throttle and the revs climb and fall without any hesitation or misfire.
After the engine has been running for 5-10 mins so fairly warm, I open the throttle again, this time it hesitates, then as I let off the rev counter falls dramatically downwards to zero and then back up to idle speed! If I repeat the procedure it backfires and more often than not stalls. Then it is difficult to start back up.
It obviously seems engine temperature related so i have ordered another ECU temp sensor, which should arrive tomorrow; i just cant explain the rev counter!
Any help would be gratefully received.
Cheers.
Powers
My local motorfactors have just got in touch to say they cant get a ecu temp sensor!
Where can i buy one from?
Cheers again.
Powers
Soured an Ecu temp sender and that hasnt made a difference.
Changed coil, again no difference.
The parts that are new:
Spark plugs, leads, dis cap, rotor arm, ignition amp (tried a new intermotor 15010 and it didnt even start!), crank angle sensor.
Could it be one of the 6 wires (Bx 16v loom into 205) are shorting!
If the rev counter is dropping to zero with the engine running then I'd double check the ignition amp/wiring, crank sensor, and ECU relay.
No rev counter output means that you're not getting an output from the ignition amp, and hence either that's at fault, the ECU isn't recieving a timing signal from the CAS, or the ECU's not receiving any power.
The fact that it's backfiring alot means I'd suspect ignition amp first and foremost as it sounds like it is still injecting fuel (which isn't being ignitioned and is chucked into the exhaust).
Powers
Thanks Anthony. Would the correct ignition amp be the 5 pin one from gsf part number N92350?
Cheers again
1.6/1.9 8v ignition amp from a 205 GTi is the same as an Mi and you've probably got one kicking about I'd imagine?
