mak 0 Posted July 20, 2006 I've got bilstein streetline shocks front and rear and to be honest its just dangerous...the car is so twitchy over the bumps its a constant battle to keep it under control. Even the smallest of bumps send the car into shock.... Its got to the point where I'm considering go back to a standard set up, but jsut before I do does anyone else running a similar set up experience similar problems? Share this post Link to post Share on other sites
fiji bob 0 Posted July 20, 2006 (edited) are you using lowering springs? if so the streetline shocks are supposed to be standard spec so that might be the problem, and yes the front end can get a bit bouncy on mine now and again with eibach springs and streetline dampers Edited July 20, 2006 by fiji bob Share this post Link to post Share on other sites
johnrobertgordon 0 Posted July 20, 2006 I'v been running bilstiens for about a year now. And have just ordered a second set (the grp N struts with larger inserts). I think they are fantastic. What springs are you running? Share this post Link to post Share on other sites
mak 0 Posted July 20, 2006 I think theyre -30mm, not sure of make but they're blue if that helps?? I'd assumed they were part of the streetline kit. Share this post Link to post Share on other sites
johnrobertgordon 0 Posted July 20, 2006 If your not too fussed about ride height change the springs to standard items, this is what i used when i was rallying it, Still feels stiffer than standard. If you like the way it handles like this i can give you a number for a guy who can get lowered standard rate springs. Share this post Link to post Share on other sites
TEKNOPUG 3 Posted July 20, 2006 Streetlines are bobbins Share this post Link to post Share on other sites
luggy 13 Posted July 20, 2006 Hi Mak Ive got streetlines on mine, rear set to standard height and the front was dropped by 30mm and they were blue springs from Auto five, never had problems on A road or B road blasts, but because I use my 205 daily drive for work it got bloody annoying with speed bumps and sleeping policemen. So put it back to standard but now the front is a bit too spongy e.g coming off the motorway slip road, so will go for 309 gti springs instead, never had an issue with the rear shocks being too soft, had them on for nearly 2 years. Luggy Share this post Link to post Share on other sites
Miles 331 1 Cars Posted July 20, 2006 Are the Streetlines the std replacement ones in black? if so the best place for these is the bin, Have a search for a post by Simes a couple of years ago, I said the same thing when I drove his car Share this post Link to post Share on other sites
Russelltp 0 Posted July 20, 2006 I've found the streetline front shocks to be fine for general use but the rear are way too soft, as soon as I swapped them for some orange KYBs (no idea what spec they are) the ride and turn in improved so much it was a different car to drive. Share this post Link to post Share on other sites
fiji bob 0 Posted July 20, 2006 id agree with the above i actually thought the rear shocks were knackered once they had bedded in fronts are alright but would swap for uprated ones if i had the cash Share this post Link to post Share on other sites
jonnie205 1 Posted July 20, 2006 Rears are horibly soft and front are like standard, bin them in favour of koni's or sprintlines Share this post Link to post Share on other sites
Edp 67 3 Cars Posted July 20, 2006 Ive got streetline shocks on my Mi and find them ok. I changed to the lowering springs too but mine are red, i think they lower about 25-30mm? I do feel the bumps more but thats part of lowering the car isnt it? Mine dosent feel twitchy one bit, it feels planted. I find them ok for the road but i guess they would be s*it for all you turborallyslagnutterbastards. I didnt fit the rear shocks as ive heard they are too soft. I just kept the originals at the rear. Share this post Link to post Share on other sites
Simes 248 2 Cars Posted July 20, 2006 (edited) Are the Streetlines the std replacement ones in black? if so the best place for these is the bin, Have a search for a post by Simes a couple of years ago, I said the same thing when I drove his car The rears are dog s*ite - soft as anything. One of many Final straw Replaced with Skip Browns so much better. Fuji Bob I'm still waitng for you to try out the Skip Brown fronts!! Only £130 each. Edited July 20, 2006 by Simes Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted July 21, 2006 Are the Streetlines the std replacement ones in black? if so the best place for these is the bin, Have a search for a post by Simes a couple of years ago, I said the same thing when I drove his carIs that what you fitted to my 405 Miles? They do seem quite soft! Share this post Link to post Share on other sites
mak 0 Posted July 21, 2006 well its good to know I'm not just being a girl about it and they are poop. appreciated guys, ta Share this post Link to post Share on other sites
fiji bob 0 Posted July 21, 2006 The rears are dog s*ite - soft as anything. One of many Final straw Replaced with Skip Browns so much better. Fuji Bob I'm still waitng for you to try out the Skip Brown fronts!! Only £130 each. one day maybe Share this post Link to post Share on other sites
Alan_M 66 1 Cars Posted July 21, 2006 The rears are dog s*ite - soft as anything. One of many Final straw Replaced with Skip Browns so much better. Fuji Bob I'm still waitng for you to try out the Skip Brown fronts!! Only £130 each. £130 each??? 'Challenge' spec Billies are only £10 more than that for the fronts. Share this post Link to post Share on other sites
fiji bob 0 Posted July 23, 2006 whats the difference? just the valving? i was told there would be a 4 week wait 2 or 3 times so didnt get them in the end Share this post Link to post Share on other sites
newdean0 0 Posted July 25, 2006 The fronts should be fine - if it's only bouncy occasionally it's likley you are hitting the bump stops. I had to trim about an inch from my bump stops and now the ride is pretty good. I'd bin the rear shocks though and replace them with standard. Share this post Link to post Share on other sites
