johno_78 2 Posted July 18, 2006 as the title says really as i have seen a 1.6 recon beam but wont bother if it aint as good as a 1.9 one. Share this post Link to post Share on other sites
max0 5 Posted July 18, 2006 (edited) as the title says really as i have seen a 1.6 recon beam but wont bother if it aint as good as a 1.9 one. you really want a 309 GTI beam as there wider (40mm) and have better torsion / anti roll bars to improve handling if you have a 1.6 beam already you can use the anti roll bar / torsion bars to make up a base model beam if yours is dead. base model beams dont have the bulge in the middle. Do a search as its been covered a lot but to answer your question i think they are the same but the trailing arms are slightly different to allow for the disk brakes Andy Edited July 18, 2006 by max0 Share this post Link to post Share on other sites
Jonmurgie 2 Posted July 18, 2006 But to answer your actual question, yes the 1.6 and 1.9 bams are the same except for the brakes Share this post Link to post Share on other sites
johno_78 2 Posted July 18, 2006 excellent, thanks for that Jonmurgie Share this post Link to post Share on other sites
max0 5 Posted July 18, 2006 excellent, thanks for that Jonmurgie sorry for the long winded post Share this post Link to post Share on other sites
inferno 1 Posted July 18, 2006 so just to throw a spanner in the works... my 1.6 abs beam is actually the same as the 1.9 beam also? Share this post Link to post Share on other sites
Veero 1 Posted July 18, 2006 my 1.6 abs beam is actually the same as the 1.9 beam also? Are you asking us or telling us? Surely a 1.6 ABS beam will have all the motion sensing stuff on (as in the ABS gear) which most 1.9 beams don't so how can they be the same... Veero Share this post Link to post Share on other sites
inferno 1 Posted July 18, 2006 i was asking... hence the question mark Share this post Link to post Share on other sites
Anthony 1,003 Posted July 19, 2006 1.6 and 1.9 beams are the same apart from the following: Brakes themselves Stub axles and hub nuts Wheel bearings Rear caliper mounting Standard ride height (1.6 are slightly higher) The main parts - tube, torsion and anti-roll bars, trailing arms, shafts etc - are all the same (the exception being the very early 1.6's, but they're very rare now) To the best of my knowledge, 1.6 ABS cars had a standard 1.9 beam fitted but used a different rear brake compensator to the 1.6/1.9 non-ABS Share this post Link to post Share on other sites
Veero 1 Posted July 19, 2006 i was asking... hence the question mark Well it wasn't totally clear since the sentence was a statement with a '?' tacked on the end So 1.6 ABS cars didn't have the motion sensor or toothed parts (like on the ABS front driveshafts)? So did they just work on if the front wheels were locked up or not? Veero Share this post Link to post Share on other sites
Anthony 1,003 Posted July 19, 2006 So 1.6 ABS cars didn't have the motion sensor or toothed parts (like on the ABS front driveshafts)? So did they just work on if the front wheels were locked up or not? Correct - 205/309 ABS was just a two wheel system that worked on the front wheels, and has a load-based compensator for the rear wheels. No speed sensing on the rear hubs at all. So rather primative compared to modern ABS... Share this post Link to post Share on other sites
Emmy Seize 8 Posted July 19, 2006 Correct - 205/309 ABS was just a two wheel system that worked on the front wheels, and has a load-based compensator for the rear wheels. No speed sensing on the rear hubs at all. So rather primative compared to modern ABS... Not exactly. The system has only two wheel sensors at the front but this doesn´t mean it only affects the front wheels. The rear pressure is controlled via magnetic valves which are operated by the ABS ECU. Rear brake pressure is calculated in relation to the "behaviour" of the pressure in the front lines. Share this post Link to post Share on other sites
