alternatengine
Nipples!
alternatengine
Not what your thinking DIRTY BOYS!
I have a full set of AVO coilovers on the front of my Pug. Not a hundred percent sure what causes it or if theres a fix but my car has recieved some nipple like bumps on the bonnet due to impact with my strut bolts.
Is there a simple fix for this as the Auto bonnet i have is under attack!
Damn Edinburgh Roads!
tidypug
i'm afraid not mate, i have this same problem. I've swapped to gaz shocks hoping it would solve this, which it hasn't
alternatengine
This may seem a bit extreme but what about shortening the bolts?
I DUNNO!
Revla
I DUNNO!
I haven't had this with my Gaz using eccentric top mounts....... :blink:
tidypug
i've just used regular top mounts, actually thinking about it i've never replaced them so they're probably ready for some new ones
mak
I have nipples inthe middle of my bonnet, not a clue how they got there but there you go.
Anyways get the yelloe pages out and look for a local dent man. Most can be pulled out form the underside of the bonnet.
Craigb
Are your strut top flat ?
This usually comes about after years of hard pounding when the strut tops bend in the middle. Knocking them back and welding a reinforcement plate on does the trick on the rally car .
May be of some help , maybe not :P
sorr
Try using the adjusters on the front of the bonnet to raise it slightly.
pugpete1108
what ? no nipples ? i am well dissapointed now ;)
