Jrod
How To Remove Drums
Jrod
I've undone the hub nut but the drum won't come off.
in the haynes it says you can depress the handbrake lever with a screwdriver... what huh how...?
pugrallye
if you get a torch and a long thin screwdriver you can flick the adjuster back through a wheel bolt hole, it looks like a knurled nut, or if your changing the shoes just get a hub puller and yank the thing off
Edited by pugrallye
Jrod
Got it. Thanks! :)
