Guest FALAHPET
Tyre Valve Caps Stuck On
Guest FALAHPET
Hoping not to sound a bit dim,
has anyone got a solution to getting aluminium valve caps off?
Tried pliers, but daren't try harder for fear of damaging the valve. :)
Jrod
Only way I could get mine off on my motorbike was by having new valves fitted. :)
justinv
normally they have hexagon heads try using a socket and t handle, had one budged on my 306 and thats how i got it off, almost tore valve away but managed to remove cap without damaging the valve
ste996
As Jrod said, get them cut off and new valves put in. Have had the same happen to me, Dont use ally caps no more. Put some gease on the valve if you do put some on the car again.
