NoodleVille 0 Posted July 16, 2006 i am starting to get agrovated by my oil pressure it seems to be in the red all the time rarely comes out of it only to drop back in it again i dont know what causes low oil pressure apart from petrol contamination lol as i read in a searched thread so any clues on what low oil pressure is means what it does havent got a clue i am getting the impression that the oil pressure sensors and sendors themselves arent very fool proof so anyone know how i can test the oil pressure myself ??? thanks guys this is my first 205 gti so it taking me a while to get used to the little qwerks Share this post Link to post Share on other sites
jackherer 543 Posted July 16, 2006 does the oil pressure light come on when the gauge is in the red? if not then its probably the sender or wiring (assuming the light works at all, it should come on when you turn the ignition on and go out when the engine starts) Share this post Link to post Share on other sites
Bono 0 Posted July 16, 2006 I had an oil pressure gauge that was all over the palce, turned out to be a dodgy wire on the back of the clocks. It would work for 5minutes if you hit the top of the dashboard Share this post Link to post Share on other sites
NoodleVille 0 Posted July 22, 2006 yeh thanks for the replys guys i fiddled with the wire and it blipped again i think its a dodgey wire because the warning light doesnt come on so i gonna replace a couple wires and the sendor unit Share this post Link to post Share on other sites
inferno 1 Posted July 22, 2006 my normally good oil pressure has been up and down for 2 days now.tonight was wierd, took it out in the cooler air, got some decent performance at last, but the oil started losing pressure, red light flickering on idle ect, then all of a sudden its back up to normal! low oil levels can cause low pressure, im not using any oil though! Share this post Link to post Share on other sites
Wurzel 16 Posted July 23, 2006 It's sort of been said already, but a low pressure guage is not always bad news. The red light (fed by the pressure switch - a totaly seperate entity) is pretty bad though. I've had low pressure since rebuilding my Mi. I've not been too worried about it as oil changes reveal nothing untoward and the red light hasn't come on. She still sounds ok for an Mi as well. Pay heed to the red light though and ensure that's working fine, it could be your saviour Share this post Link to post Share on other sites
sorr 0 Posted July 23, 2006 I have always found French mechanicals to be far better than French Electrics. Of the two 205s I have owned oil pressure problems have always been bad electrics. To check run a cable directly from the sensor to as close to the gauge as you can get. Share this post Link to post Share on other sites
aw11_hgt 0 Posted July 23, 2006 (edited) It's sort of been said already, but a low pressure guage is not always bad news. The red light (fed by the pressure switch - a totaly seperate entity) is pretty bad though. I've had low pressure since rebuilding my Mi. I've not been too worried about it as oil changes reveal nothing untoward and the red light hasn't come on. She still sounds ok for an Mi as well. Pay heed to the red light though and ensure that's working fine, it could be your saviour Is the red stop telltale light not fed off the oil pressure gauge?? If so its quite possible to have good oil pressure, but a dodgy gauge, that in turn puts the red stop light on. (fingers crossed anyway!) Edited July 23, 2006 by aw11_hgt Share this post Link to post Share on other sites
Bono 0 Posted July 23, 2006 the oil warning light, and therefore i assume the stop light is fed from a pressure switch seperate to the pressure gauge sender. So if the red lights come up then its probably best to stop :S Share this post Link to post Share on other sites
jackherer 543 Posted July 23, 2006 Is the red stop telltale light not fed off the oil pressure gauge?? If so its quite possible to have good oil pressure, but a dodgy gauge, that in turn puts the red stop light on. (fingers crossed anyway!) read Wurzel's post (the one you quoted) more carefully, the light is connected to a switch that is totally seperately from the gauge, the only thing they have in common is the oil itself! Share this post Link to post Share on other sites
NoodleVille 0 Posted July 25, 2006 well that is good news then i guess my oil pressure light comes on when ignistion is on if the warning light doesnt come on but the guage is in the red whats the point in having a guage why have a guage that doesnt actually warn you of anything lol i will just follow back all cables and probably replace the sendor unit as well cheers for the feedback guys i will post on here again when i have fixed the problem Share this post Link to post Share on other sites
Guest judgefudge Posted July 25, 2006 Been having a bit of grief myself. Yesterday my pressure gauge needle was sat in the red at hot idle, however the warning light wasn't lit so I ignored it. Did a search on here and went out this morning and checked the warning lamp lit with just ignition on.. it didn't, arse. Dug an old leccy pressure gauge and sender I had from one of my old Escorts, fitted it ghetto style and went for a burn.. good news. Im getting a rock solid 50+psi at 3k rpm and 20-25psi @ idle (900rpm), oil temp gauge needle is pointing at the second thicker marker.. ie.. nice and warm. |If your in any doubt get a cheap gauge in there with some proper marks on it, I've had this £15 Tim guage about 4years, it's not the most accurate but at least it's better than a lot of the stock gauges. Share this post Link to post Share on other sites
Guest RickGTIBaker Posted July 26, 2006 Mine is fine when first started, heated up it idles on almost no reading. That to me is overly thin oil. Sawdust time (Kidding) Share this post Link to post Share on other sites
NoodleVille 0 Posted July 27, 2006 |If your in any doubt get a cheap gauge in there with some proper marks on it, I've had this £15 Tim guage about 4years, it's not the most accurate but at least it's better than a lot of the stock gauges. ok thats very usefull bit of info i have no clue were i can get one from though if anyone knows post a reply or pm would be great i will go buy one asap just wanna know my car is ok Share this post Link to post Share on other sites
