Anton green
Fuel Consumption Up
Anton green
what could the problem be if my 205 is suddenly using a lot more fuel than normal? its a standard mi16 and its running a little rough too??
The cooling system has decided to leak a lot recently, could this be anything to do with my fuel usage probs?
(I am replacing pipework this weekend to deal with this..)
Thanks in advance, Anton
Pug_101
The cooling system leak could be a part of it, but I suspect the engine cooling sensor could be on it's way out. This would make the engine think it's running cold and the mixture would get a lot richer all of the time.
Anton green
Aha! that would be the blue sensor mounted forwards of the distributor, with the battery to the right of it? How might I test this to see if it is the problem?
futura
I think the testing procedure is described in the Haynes manual. You need to test the resistance value at different temperatures, usually people boil water and chuck the sensor to test it!
I have a spare one if you want. I couldnt be bothered testing it, so I just bought a new one (was dear!) and unfortunately for me it didnt sort my starting problems.
PM me if you're interested.
Anton green
Im taking the car to a specialist today so will know more shortly.
Simes
ECU temp sensor is £10 from GSF.
Save your money on the specialist and just replace the part.
Anton green
been there. could find nothing wrong - its perfect apparently.
I can smell fuel sometimes when driving it, so Im now thinking its a petrol leak...
