j-16
Wishbones
j-16
Hi,
There's lots of topics around on wishbones but what i can't see is, is it possible to replace the boot over the ball joint? Surely it's not necessary to replace both wishbones because of split boots?
Cheers,
James
steve@cornwall
  j-16 said:
Hi,
Cheers,
James
Clean with meths (carefully) and smear with tiger seal or similar- should be a permanent repair and satisfy the tester! Especially useful if you damage them when removing the hub as you've not lost lubricant.
mi16nut
An 'old school' motor factors amy be able to find you something that will fit. I'm sure it's been mentioned that boots from a Morris Minor or similar could work.
Mark.
Bats
J16, send me a pm with your address and I'll send you a pair of new replacement boots that will fit. I bought a packet of several boots and replaced both mine - so got a few spares.
jonD6B
Where did you buy them from?
Gentrix
Bump
I need a pair of those boots, too. There did you get them from?
Somebody any ideas?
thanks
andi
boombang
I bought some random boots on ebay and they fitted perfectly fine. VW fitment I think
oli-pug
edit: just realised this thread is 7 months old
do you know what vw they're off boombang?
Edited by oli-pug
Beastie
It was probably me who mentioned that Morris Minor track rod end boots fit the ball joints really well. I fitted a pair to mine when I bought it 5 years ago and they are still going strong 40,000 miles later. There are loads of Morris suppliers around the country so they might be worth a try.... it's been 6 happy years since I owned a Minor so I'm a little out of touch with all that sort of stuff at the moment :)
Gentrix
I heard today, that a boot of a Track Rod End will fit. And I have a spare one somewhere in my Garage. Will have a look at it.
andi
VisaGTi16v
Let me know if it does as I have a pair of 309 arms to go on my car but 1 boot is shot. I thought you could buy them seperately but not according to this thread? Track rod ends are dirt cheap on ebay though.
Gentrix
Tried to rip the boot of the spare 106 Trackrodend, but failed. They are glued on with Sickaflex or similar. So I ended up with an other split boot.
:blink:
VisaGTi16v
doh. Must be able to get them from somewhere as they are removeable, will ask at the garage round the corner, waste of a good 309 arm otherwise although I could probably just swap one over from my 1.6 arms if I swapped them
oli-pug
i managed to get a pair yesterday from my local motor factors "shelltune"
just took the split one in and they matched it. cost 2 quid each
VisaGTi16v
ah cool thanks
Gentrix
can you post a partnumber or something to identify the boot, so that I can ask our suppliers to get me those?
Do you had do glue them on?
andi
