John_205_GTi
Oil Leak
John_205_GTi
recently noticed an oil leak, upon further inspection the oil appears to be running down the inside of the flywheel, does anyone have any ideas where its comung from and how easy it is to fix?
thanks
kyepan
thanks
possibly crank shaft oil seal, or further up from under the distributor / cam shaft o ring, second is more common and very easy, first is a gear box off job before you can get to it.
:blink:
