matty_gti
Engine Marks
matty_gti
hi all, how do you tell the different engine marks. i need to replace my engine and i want to know as much as poss. is the coil on the mark 1.5's and 2's on the passenger wing next to the water expansion tank???? :blink:
Or is there any obvious signs that tell me wot mark it is???
Cheers.
M@tt
not entirely sure what you mean mate by "marks"??
do you mean different versions of the car as in phases? eg ph2 = black interior and clear indicators etc or are you thinking there are different versions of the engine?
i might be completely missing the point but is that what your asking?
Matt
matty_gti
yeha i mean different versions of the engine. I know theres a phase 1 enigne (105bhp) and theres a phase 2 engine (115bhp)
My GTi is a phase 1.5, (F reg) it has phase 1 lights and a be1 gear box but a phase 2 dash board and engine i belive. It has torx head bolts instead of normal headed bolts, and on the throttle housing you can only change the idle speed and not the mixture i think.
Hope that helps.
M@tt
well if you got a 1.6 gti then you will have/need a xu5 engine 115bhp
and if you have a 1.9 gti then you will have/need the xu9 engine 130bhp
it's very unlikely you'll have a 105 bhp block which was the low compression 1.9 one and pretty rare
HTH
