Guest CJG122
Hosed Engine To Check For Leaks
Guest CJG122
I gave the engin bay a hose to clean it out - not the brightest of ideas as I did not cover any electrical connections! :)
My radiator fans no longer turn on.
Occasionally - whilst driving - the engine, for up to 5 seconds will rev high but no response - then it kicks back in.
Any advise/Help !
hexhamstu
"whilst driving - the engine, for up to 5 seconds will rev high but no response - then it kicks back in."
i dont understand this bit?
Edited by hexhamstu
jonD6B
Probably just knocked the wiring connector off the rad.?
Guest CJG122
Got the radiator working. I think it was the ground conection causing the trouble.
meaning that at random the engin will have no response - as though the battery has cut. Often in 3 rd gear. I give it more throttle and the revs go up but no response. Once changed to 2nd gear I get a little feed back and then after about 5 seconds all is back to normal.
Quite worrying as it happens without warning !
hexhamstu
well i would check the distrubtor cap and rotor arm, for water give a good dry out.
Guest CJG122
This problem still occured after I had cleaned out the distributor cap and spark plugs. It has not reoccured since I got the radiator fans working - yet.
Edited by CJG122
Rob_the_Sparky
Getting the engine warm is generally a good way of drying things out (if it runs that long!) I'd also check the spark plugs, if they have water in them it won't help.
Rob
