Guest alan Posted July 6, 2006 I have a 205 1.9 cti the hood ,horn and washer have stopped working. all fuses are o.k.I need to find the relay switch for my washer and horn. i have cleaned all the earths, also if i run them individualy from the battery they work. can someone please point me in the right direction. as i think im going mad Share this post Link to post Share on other sites
smugpug205 0 Posted July 7, 2006 I have a 205 1.9 cti the hood ,horn and washer have stopped working. all fuses are o.k.I need to find the relay switch for my washer and horn. i have cleaned all the earths, also if i run them individualy from the battery they work. can someone please point me in the right direction. as i think im going mad Hi mate, with the bonet open, look on the n/s/f near the header tank you should have two relays (green) one is the horn relay i belive!! I had a problem with my washers and found it to be the plug on the washer pump, try removing it and with a flat screwdriver clean the contacts on the plug and pump. Hope it helps Adrian Share this post Link to post Share on other sites
Guest alan Posted July 10, 2006 cheers for your reply, i tried that after reading it, and still no joy, , back to the drawing board, i might have to go to plan B but which involves to things, a hefty bill, and a auto electrician. Share this post Link to post Share on other sites
Cameron 16 Posted July 10, 2006 (edited) Edit.. misread the question.. Edited July 10, 2006 by Cameron Share this post Link to post Share on other sites
Phil H 16 Posted July 11, 2006 (edited) Hood not working...check that the oil pressure switch works...this is the failsafe to stop it being operated when the engine is running. The other bits are probaly a duff pump and corroded connectors, Edited July 11, 2006 by Philip Hills Share this post Link to post Share on other sites
