shine
Oil For Be With Quaife Lsd?
shine
Hello
What kind of oil do you recomend for Be1 box with Quaife LSD?
Can I use same type of oil as with std diff? I used to run with Castrol SAF-X0
Espen
Ryan
I'm pretty sure Quaife say just to use whatever you'd normally put in.
I'm using the Morris semi synthetic stuff from GSF, standard gearoil & nothing fancy.
d-9
Be sure to fit the diff correctly, setting the preload on the bearings with the correct size shim, this is not mentioned in the guide on the main page.
Guest Steen-S 309 GTI 16
Please explain the correct settings.
B1ack_Mi16
AFAIK there is no shim on the newer BE boxes, only the very very early ones has one (I've never seen one).
Only place I found a shim in my BE box was on the input-shaft, and that won't be any different when changing the diff.
The casings are at least supposed to be correct machined from factory and shouldn't need a shim.
(At least as long you haven't taken the part with the speedo-drive and changed it to one fraom another box, then I guess tehre could be some problems..)
That was just my thought, I have never seen any shims when I fitted the Quiafe diff.
like what? I've done that before and it seems fine :unsure:
B1ack_Mi16
Like that the bearings is likely to get either too much or too less preload due to the casing lip that enters the diff housing is too short or long.
But maybe they're even produced with such small tolerances that it ain't a problem anyway.
I;ve only seen a couple of boxes with the diff shims and they had the even earlier Metal selectors inside, era of around 1984!! But B1ack's spot on the cases are machined to suit, Yes you can change them normally without any problems as they do wear as well
SPGTi
I always use Total BV oil as recommended by Peugeot and available very cheaply from GSF. The Pug recommended oil is a bit thinner than std and is easier on the synchros (so I was told by a gearbox specialist).
steve
midnight motorsport
i normally run gl5 fully synthetic, quaiff recomend gl4 or gl5, silkolene is what i normally run in my gearboxes, never had any problems :)
