t16ryan
Chipped Ecu
Ryan
I wouldn't. It will run, but the fueling will be all wrong.
richsmells
Think they raise the rev limiter but as Ryan says it would probably run bad. The jetronic ECUs dont really do much anyway, not like modern mapped ignition.
Jonmurgie
A 'chipped' 205 ecu is about as useless as a chocolate tea pot... just tell him to hold out for a 1.9 ECU or put a wanted post on the forum :unsure:
jonD6B
I've got a 1.9 ECU if he wants it. PM me.
t16ryan
is it standard or chipped?
Doesn't look like a proper Superchips ECU to me, Just a sticker added on, The rev limit is easy to remove and I have both types of ECU in stock unlimited just for the Mi16 engine or the old 8v one.
The Jetronic system is basically a load of resistors and the old fueling mod was just a couple of varable ones to adjust the low end rev range,
jonD6B
Standard. Do a search on here and you'll realise that 'chips' for the 205 are pretty much a waste of time.
d-9
Chips go well with a burger and coke thou :unsure:
