jamesc 3 Posted June 30, 2006 Have taken them out but broke/cracked one of the little caps that goes on before the O ring. It's gone back together ok but obviously the crack is visable is this a problem? Rang citroen and they said they no longer supply them?!? Share this post Link to post Share on other sites
Jonmurgie 2 Posted June 30, 2006 If you mean the cap on the very end of the injector then it should be fine as it's only a bit of protection and doesn't effect the fit or flow of the injector... If your concerned then I have some spare Mi16 injectors... Share this post Link to post Share on other sites
