Guest leegt Posted June 29, 2006 (edited) dint know where to put this topic so here goes, got a wiring loom off ebay when it arrived it was a bit, well... f***ed. but managed to sort out most of the wiring apart from the coil, just need to know which connection to use, pos and neg, (as there are 4 as far as i can remember) and is it possible to just use a switched live from the ignition switch if i cant find the correct wire/s on the loom, cheers lee Edited June 29, 2006 by leegt Share this post Link to post Share on other sites
