jamesc 3 Posted June 29, 2006 Just rang up citroen as i need a new oil temp sender (thing in the bottom of the sump next to the sump plug) and they have asked how old the engine is as apparently the part changed.. I have no idea how old the engine is or what year car it came out of, anyway of telling? Cheers Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 29, 2006 Not sure what year they changed but the thread is possibly different, I know they changed the sump plug size on later cars but not the year. I had a BX TRi with a smaller thread oil temp sender which was a 1989/90 car. Can't you give them the engine number & let them find it that way if the donor was definately a BX? Other differences can be alloy or steel sump (or block depending on donor car) but I don't think any BX's had the alloy sump or steel block Mi fitted. Graham. Share this post Link to post Share on other sites
Ryan 99 Posted June 29, 2006 My BX engine has the alloy sump, and I've seen at least one other with it too. Share this post Link to post Share on other sites
jackherer 543 Posted June 29, 2006 but I don't think any BX's had the alloy sump or steel block Mi fitted. there were definitely no steel block BXs but I've had several with alloy sumps. Share this post Link to post Share on other sites
Kitch 4 Posted July 4, 2006 Most BX 16v's have an alloy sump, even if they didn't have A/C Share this post Link to post Share on other sites
pacey205 2 Posted July 4, 2006 Mine had an alloy sump but no A/C Michael Share this post Link to post Share on other sites
kate205gti 4 Posted July 4, 2006 H reg onwards have a knock sensor if that helps?? Share this post Link to post Share on other sites
mike parsons 0 Posted July 4, 2006 4 digit number printed on the passenger side front pillar of the Bx is the ORGA number that's needed to be quoted to Citroen for a whole number of parts. Guess you haven't got that, or can you take the existing part to the dealer to show them? Mike P. Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted July 4, 2006 H reg onwards have a knock sensor if that helps??1991 h reg Share this post Link to post Share on other sites
kate205gti 4 Posted July 4, 2006 and alloy sumped mis were made 88-92 - whats ur point?? Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted July 5, 2006 Och moody! Share this post Link to post Share on other sites
