Eryl1.9Gti
Aerial Wire
Eryl1.9Gti
lost my aerial cable when my stereo got nabbed, no idea why it went along with the HU should have just poped out and been there whith all the other wires, but its not.
So where does the wire come from. Had a look down where the HU is and there aint no sign of it, how is the aerial routed and what does it look like (colour).
Thanks Ez.
timmsy19
its comes down the right hand side of the car in the front door pillar, should be routed under the steering wheel somewhere and then on the right side of the hole where the HU goes.
if that makes any scence
StuartE
It's routed above the steering column with all the other wires then goes down behind the heater box.
You can't miss it either assuming it's the same shade of pink as mine.
Ren
As above, mine is a lovely pink colour too, my Roland Garros had a bright blue one though but it ran down the same place.
timmsy19
just what i meant. over the steering column :D
mine is pink my brothers is blue, it all depends on year and what pug decided to pull out the big bin full of odds and sods i think
Edp
I replaced mine (pink by the way) for proper expensive coax cable i was using on a job. The radio has never sounded so good!
timmsy19
im thinking of doing the same when i replace my aerial as its snapped off the base.:D
Eryl1.9Gti
Cheers for the info guys, will have a dig around for it.
Ha ha i snaped my aerial off aswell but it still worked, was a bit too eager to clean the car couldnt get the brush under the aerial so i tried to move it and it just snaped off in my hand, just forced it back into place and it worked fine :)
timmsy19
yep mine happened the same way but left it of now its just the base and still works................well kind of if its a nice day
