leigh1900
Whats This
leigh1900
working on electrics today on h plate 1.9 and i removed a 4 inch cylinder device from behind pass side head light it was badly coroded and split with one wire snapped. it has 3 wires and was connected to a brown 3 pin plug with only 2 wires connected to it. any advice much appreciated
cheers
leigh
inferno
hahaha if thats 4 inches she must be trying to make u feel good about your weener!
but i dont know what it is... sorry!
leigh1900
no worries i take it mine must be bigger than yours. hopefully someone will know what this thing is for
cheers
hengti
sounds like the dim dip resistor for the headlights
with the ignition off, turn on the side lights - the sidelight bulbs (seperate to the main bulbs) should come on. then turn on the ignition - the main bulbs should also come on (dimly) - if this doesn't work, it sounds as though the resistor/wiring has had it
careful though - there's another identical looking one near by for the rad fan switch - it's often found ontop of the radiator. this one definately needs to be working!
leigh1900
thanks a lot for that i'll check that tomorrow. just another small question ive posted this on another post but i can't find the plug that goes to the gearbox sensor and was wondering if this may have been attached to the 2 pin socket that is located next to the expansion tank on pass side of car as there is a plug there with nothing attached to it
cheers
leigh
Which gearbox sesnor?
There is only the reversing light switch plugged onto the gearbox.
If the plug you have found is a red two pin one then don't worry, most (if not all) 205's have them. No one has found what its for yet afaik.
Graham.
leigh1900
cheers ive found that plug also but the one ive found sits right next too the expansion tank and its white. as for the reverse plug to the top of gearbox i dont have that one anywhere in the loom any suggestion as to where that wire goes back from the plug to the wiring loom would be welcome
cheers
leigh
j-16
4" cylinder - compressor for horn? Below headlight by the end of the radiator.
Ren
Does this sit to the side of the expansion tank on the strut top? 2 pin? If so I have this and it is not plugged in to anything. Was wondering what it was for as well.
leigh1900
dont think so it is attached right behind the headlight on a clip but is def not a compressor its about as thick as a roll of 10p's
cheers leigh
thats the one. the guy that put the engine in left loads unplugged so just thought that this might have been one of his missed efforts
cheers
leigh
