205_sunderland 4 Posted June 25, 2006 i purchased a rear beam last year for 20 quid of a 205 rallye, the beam is quite new. ive never even looked at it fully really, but upon further inspection i noticed it has avo rear shockers with polyflex bushes, they looks quite new really, i was woundering what would be the best way to check them as im actually in need of rear shockers at the moment as mine are weeping, i kno they are usually ok if once pressed down they return nice and slowly. I was also curious if you can get them reconditioned nad if so how much? regards michael Share this post Link to post Share on other sites
Miles 331 1 Cars Posted June 25, 2006 Avo do reapir them, I;ve sent quite allot back to them and turn around is good, Bar that I can;t remember how these should work, I think they have no bump only rebound responce Share this post Link to post Share on other sites
205_sunderland 4 Posted June 25, 2006 so it looks like there ok then because they seem to return fine now whilst on beam so how much would they charge to recon them if they do need it, anyone? regards michael Share this post Link to post Share on other sites
rally ax 0 Posted July 3, 2006 Phone and speak to Nigel,I've been using Avo's for years and find the service really good and not too pricey -never much more than £20 a damper. Depending on what your planning to do with the car ,you can get the stiffer valving for track use etc if you want. I've not long bought some tasty 2 way adjustable Monotubes c/w remote canisters for the back of my Ax . They also do 2 way adjustable twin tube dampers . AVO - 01604 708 101 Share this post Link to post Share on other sites
