fiji bob
Cam Timing....again
fiji bob
the timing is set so that the engine pulls well from low revs so it suits my driving style atm :P the problem is it occasionally stutters when pulling from low revs usually only does it once but i was wondering if it might cause damage to the valves? still pulls alright at high revs but ive pushed my luck in that regard too far already.
Jonmurgie
Stuttering won't cause any issues with the valves... does it pink when you floor the throttle at low down revs?
fiji bob
i only asked in case the timing was far enough out that the valves might end up being burnt, theres slight pinking when thje engines hot and labouring but nothing much really.
