hodgy 0 Posted June 23, 2006 i wanna change my BE1 box to a BE3(i think, bottom right reverse) as its a fully custom box, is it a straight swop apart from having to change the gear linkages n the gear stick over? any light on this will be appreciated!thanx Share this post Link to post Share on other sites
steve@cornwall 100 Posted June 23, 2006 i wanna change my BE1 box to a BE3(i think, bottom right reverse) as its a fully custom box, is it a straight swop apart from having to change the gear linkages n the gear stick over? any light on this will be appreciated!thanx plus clutch cable and pedal Share this post Link to post Share on other sites
Miles 331 1 Cars Posted June 23, 2006 you only need the clutch cable and pedal, Every thing else fit's fine. The linkages will need adjusting thou Share this post Link to post Share on other sites
hodgy 0 Posted June 24, 2006 i can just buy a new cable tho cant i, so looks like i best take my clutch pedal off then before it goes to car heaven Share this post Link to post Share on other sites
jerseypug 1 Posted June 26, 2006 just done the same to mine as the clutch was far too heavy with the be1 triangle clutch arm. the clutch is great now but the lever hits the battery tray after moveing about 30mm. i dont know if there are different battery trays as well as the pedal, cable, release bearing and clutch arm. hope this helps Share this post Link to post Share on other sites
