d-9
Larger Mi16 Throttle Body
d-9
Ive been thinking about fittign a larger throttle body to my mi16, as there are a couple of R19's in my local scrappy, with a big butterfly and a smaller one that open together. Does anyone know if the Throttle body is a restriction or wether it will make no difference...or could it actually make it worse?
Guest davebxgt
The afm is a bigger restriction than the throttle body, so no point changing it unless you go for programmable ecu and ditch the afm.
Dave
d-9
ooo yeh, just realised the area of the hole in the AFM is smaller than the holes in the TB.
James_R
Also R19 bodies, if the same as clio ones won't accept a bosch TPS on to them
I've never fitted a larger TB but I took one off of my mates Mi16 that it had fitted when he bought it and put a standard one on. It didnt make it any slower.....
