brianthemagical 1 Posted June 20, 2006 i've just done a search of my afm number on the bosch website and found that it is for the i.6 gti. will this make much difference to the performance of the engine?. thanks. the number is 0280202056. Share this post Link to post Share on other sites
Jonmurgie 2 Posted June 20, 2006 Not getting your question here? You have looked up the AFM of your 205 and confirmed it's for a 1.6 Gti yeah? So what car do you have, a 1.6 GTi?! Share this post Link to post Share on other sites
brianthemagical 1 Posted June 20, 2006 sorry, it's a 1.9 gti xu9ja jettronic non-cat. Share this post Link to post Share on other sites
j_turnell 137 3 Cars Posted June 20, 2006 In which case yes it will affect performance, the fuel and air ratios are different, therefore you would deffinetly benefit from getting a second hand one or new one if you have enough cash. It shouldn't be to hard to find one they are quite common. May also be worth checking other things such as the ecu etc to make sure these are also not 1.6 items. Share this post Link to post Share on other sites
brianthemagical 1 Posted June 20, 2006 thanks. the ecu is a 1.9 one, but it has a sticker on it with IC (company logo) in one corner then the correct bosch numbers hand written on it, poss refurbed? what else would there be to check. Share this post Link to post Share on other sites
jackherer 543 Posted June 20, 2006 the distributor and the injectors are also 1.6/1.9 specific Share this post Link to post Share on other sites
Pug_101 0 Posted June 20, 2006 What AFM do you need part no wise, I have one spare. Share this post Link to post Share on other sites
