Oigen
Mid Silencer
Oigen
At this moment I have a 2 pieces exhaust system and the mid silencer need to be replaced. Can I just cut the downpipe from my system and weld the mid silencer from the 3 pieces system? The pipe between mid silencer and backbox has the same shape on both systems?
Thanks,
Dan
Edited by dassy810
Rob_the_Sparky
I don't see why not, as far as I know the only difference in the two systems is the way it joins together.
For You Info: A group N rally centre pipe has no centre silencer so you could just weld in a straight piece of pipe in place of the broken silencer.
Rob
There is a slight diameter difference (1 or 2mm) so it probably won't match straight up if you do this but using a welder shoudl easily overcome this.
Graham.
