vern 0 Posted June 18, 2006 Before you all shout use the search!!, I have and could not find the definitive answer, do all Mi flywheels have the timing teeth, and is there a difference between the 1.9 and 2.0l mi flywheels. sorry if been covered before. Vern Share this post Link to post Share on other sites
SweetBadger 94 Posted June 18, 2006 Yes and Yes Really? What's the difference between the two? I'm using a 2ltr flywheel on my 1.9 MI and its fine, i've got a 1.9 flywheel that I compared it to and the timing teeth are identical so I used the 2ltr one because it was in slightly better nic. Is there a weight difference? Share this post Link to post Share on other sites
petert 601 Posted June 18, 2006 In terms of timing, the 1.9L 8V Motronic and Mi16 (both 1.9L and 2.0L) flywheels are identical. The all have 60-2 teeth, dowelled in exactly the same position, so you can swap them around as much as you like. They also make a great degree wheel, as each tooth equals 6 degrees! Share this post Link to post Share on other sites
vern 0 Posted June 19, 2006 Thanks for replys, still a bit inconclusive the timing marks are the same all agreed, but jon says there are physical differences and sweetbadger says there are not. Anyone pass the deciding vote!!. Share this post Link to post Share on other sites
Jonmurgie 2 Posted June 19, 2006 s*ite sorry.. I meant Yes and NO then!! They are identical... Share this post Link to post Share on other sites
vern 0 Posted June 19, 2006 thanks for all replys guys. Vern Share this post Link to post Share on other sites
