Guest antgel
Draining A Be1 Gearbox
Guest antgel
Any tips for this? I can't quite get the secket on due to the proximity of the front cross-member.
sonofsam
Does it not have a hex head bolt? ie you can get in there with a hex key rather than a socket, could be wrong mind.
pugpete1108
where you draining from ? the diff , you should have room , should't you? , i usually use a square drive plug spanner but have used a socket on there
sonofsam
How did you get on?Is it the same square drive as used on the sump plug? just a thought:)
Guest antgel
I'll let you know next weekend. No time to work on the car in the week...
Sometimes you can't get a sump drain key in there as it catches the subframe & need a spanner instead.
Rob_the_Sparky
Either a big spanner or a sump plug key. I often use a large adjustable as it does not need to be seriously tight.
Guest antgel
Interesting. How tight /does/ it need to be? :P
Rob_the_Sparky
Ish! Just enough to crush the new copper washer to make a seal as it is only holding oil against gravity, not pumped oil pressure.
