Guest antgel Posted June 18, 2006 Any tips for this? I can't quite get the secket on due to the proximity of the front cross-member. Share this post Link to post Share on other sites
sonofsam 5 Posted June 18, 2006 Does it not have a hex head bolt? ie you can get in there with a hex key rather than a socket, could be wrong mind. Share this post Link to post Share on other sites
pugpete1108 62 1 Cars Posted June 18, 2006 where you draining from ? the diff , you should have room , should't you? , i usually use a square drive plug spanner but have used a socket on there Share this post Link to post Share on other sites
sonofsam 5 Posted June 20, 2006 How did you get on?Is it the same square drive as used on the sump plug? just a thought:) Share this post Link to post Share on other sites
Guest antgel Posted June 20, 2006 I'll let you know next weekend. No time to work on the car in the week... Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 20, 2006 Sometimes you can't get a sump drain key in there as it catches the subframe & need a spanner instead. Graham. Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted June 20, 2006 Either a big spanner or a sump plug key. I often use a large adjustable as it does not need to be seriously tight. Share this post Link to post Share on other sites
Guest antgel Posted June 20, 2006 Either a big spanner or a sump plug key. I often use a large adjustable as it does not need to be seriously tight. Interesting. How tight /does/ it need to be? Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted June 21, 2006 Ish! Just enough to crush the new copper washer to make a seal as it is only holding oil against gravity, not pumped oil pressure. Share this post Link to post Share on other sites
