macaroni 17 1 Cars Posted June 15, 2006 Fellow TU-ers, can anyone tell me whether the entrance to the standard inlet manifold is split into 2 circular holes or is one big oval type thing? I have one that is oval, but it was apparently modded in some way to accept the Weber DGAS carb that sits on it. I also have 2 gasket blocks, one with an oval hole and one with 2 circular holes. I can't fathom which one would be best to use. Any help gratefully received. Cheers, Antony Share this post Link to post Share on other sites
Guest smokinslim Posted June 16, 2006 I presume you mean the xs solex carb manifold(?) What does the bottom of the carb look like? Could you perhaps test both blocks and see which works best? Share this post Link to post Share on other sites
macaroni 17 1 Cars Posted June 16, 2006 Blimey, you're up late! Yes, that is just like mine. The bottom of the carb is oval, but the butterflies are the same size and shape as the holes in the twin holed gasket block. I guess I will have to try each one and see. Thanks for your reply. Share this post Link to post Share on other sites
