jonarob
What's My Engine?
jonarob
Just to confirm - 1.6 GTI 1990 on a G - is it the XU5J?
I've tried a search! :mellow:
XU5JA - the later 115hp 1.6 GTi engine :mellow:
XU5J was the early (pre-1987 IIRC) 105hp 1.6 GTi engine
(edited as Alan points out I can't type :angry:)
Edited by Anthony
Alan_M
XU9JA - the later 115hp 1.6 GTi engine :mellow:
XU9J was the early (pre-1987 IIRC) 105hp 1.6 GTi engine
Are you sure its not a XU5JA? The '9' denotes thats its a 1905cc, whereas the 1.6 is a 1580cc therefore a '5' :angry:
Pete C
Yeah, it'll be an XU5JA. The early 1.6 was an XU5J, and the 1.9 (8v) is an XU9JA...
Edited by Pete C
jonarob
cheers :mellow:
So does anyone know what spark plugs I ideally should use?
Edited by jonarob
That too.... *goes off to find some caffiene to wake me up* :mellow:
cheers :mellow:
just fit the standard NGKs.
jonarob
I got the BCP6E but my dad seems to think they're wrong. The Haynes ain't exactly helpful. Anyone know what the gap is? We're faced with 2 choices but can't work out what it is.
The electrode gap that is!
Edited by jonarob
Pete C
0.9mm is ideal apparently :mellow:
jonarob
Thing is the choices in the Haynes are 0.8 and 0.6 - sure you don't mean 0.8 or is the Haynes wrong?
Pete C
I just used the 'search' button, and found that Haynes reckons 0.8, but a few people have used 0.9 and found that it helps with idling etc :mellow:
MartinM
With a wasted spark coil, I use 1.6 (40 thou in old money) - you get a heck of a spark from these coils, so you might as well get benefit from a physically bigger spark in the cylinder...
Rob_the_Sparky
Errm 40thou = 1mm, 1.6mm is 64thou
Pete C
1.6mm to me sounds excessive anyway, but then I only really have tuning experience with turbocharged engines...
