Edd-XS
Induction...
Edd-XS
Ill openly admit I dont know an awful lot about engines, infact pretty much anything I do know is from what ive picked up from this forum and by doing research. What I do know is that the air intake is vital as to how the engine will perform. We all know that hotter air is less dense so doesnt combust as well as cooler, denser air which leads me to think, what is the maximum amount you can reasonably do to keep intake temperatures and volumes at the best possible levels to aid performance?
Im not suggesting an air flow meter in a fridge or anything silly like that, but more, what is the optimum intake method on a standard engine?
Im toying with the idea of a big heatshield (aluminium sheet!) running from behind the pass. headlight to the pass. side top mount and putting a filter where the washer bottle would normally be and having a dedicated cold air feed going into the area.
It would seem that locating the air filter over the exhaust manifold (excess heat) noticably affects performance, so would a drop in ambient temperature around the filter affect performance in a positive way?
Just food for thought really so please excuse if ive said anything stupid!
Discuss :D
Edd
pugrallye
yeah cold airbox is good idea, especially if you put a dedicated air feed to it
Edd-XS
Well when buying a pipercross induction kit, all it does is replace the old airbox for a cone filter! I read a thread on here recently about the ambient air temperatures at different points whislt on a 'normal' drive, but what I didnt see anyone mention was a direct affect that it would have on performance (unless im being stupid and missed it!).
Has anyone ever tried any special induction set-ups on MIs (or really anything) and found it beneficial?
t16ryan do you notice a change when you remove the headlight so the filter is getting direct cold air?
Call me sad but I find this all quite interesting!
Edd
pugrallye
yes, my previous Mi had a dedicated sealed airbox (with pipercross foam filter inside) fabricated out of ally, and a 95mm duct to a removed driving light aperture did make a difference in warm weather! I suppose the way to go ultimately is a ram air effect, as most of TB guys are using now
I suppose if you wanted a bit of test and tune, creating a 'tuned length' of pipework from afm to air filter has mixed reviews and successes
Edited by pugrallye
feb
Do you have any pics of this setup?
I don't see the point of having a K&N induction kit (although my car has one) in warm climates.
I measured the air intake temperatures last week with it and was surprised to see them climb up to 65C!
It's been a few years since I test drove a car with a standard setup but I don't think it felt any different to mine (i don't know how it would be in traffic but i suspect air temps would be lower than with the K&N kit)
We could only tell the benefits (if any) if we take a car to a dyno with a standard airbox, then fit the K&N kit/different setup and compare the results.
Edited by feb
pugrallye
yeah somewhere
dyno activity wouldnt give you a true reading though on either system as their is no airflow, i suppose in warm climates there isnt much difference between using a standard air box with say a K&N panel filter or a cone filter in a fabricated air box
Edited by pugrallye
t16ryan
its minimal but it helps a little more air,,, so best to do it you need all you can on the track , also i a induction kit in HOT conditions actually decreases BHP on the GTis as was tested at powerstation on the rollers
pugrallye
yeah hence you fabricate an airbox to put it in
t16ryan
when they are dynod they have 2 massive fans to blow air onto the car, if not some cars over heat as not being air coooled,
