Guest andyfitz
205 Gti Master/servo Change
Guest andyfitz
Hey guys,
The master cylinder and my servo on the 1.6 gti are a little crusty lol
We recently scrapped a 405 2.0 8v, it had a mint master/servo on it so we kept it, will this setup bolt onto my 205 without any work?
It's that or strip mine down and attack it with a wire brush and hammerite, and then find a better master.
Any help appriciated :D
smckeown
it's easy to sort the mess out, i did this in about an hour:
to:
Sean
Guest andyfitz
Aye, I could do that matey but mines pritty rusty, alot worse than that, I would rather put the good as new one I have on if I can, otherwise ill clean mine up.
Cheers for the reply dude :D
Pug_101
  andyfitz said:
Hey guys,
I remember reading about something like this and you need to check the diameter of the rod (cast into body, should be something around 20) in the master cylinder because if it's too big your'll end up through the windscreen even thinking about using the brakes :D
Do a search it was covered not to long ago.
Guest andyfitz
Thanks for the info dude, Ill check this out.
Guest andyfitz
tried a search cant seem to find much on this, does anyone know if this is a direct fit or not?
And I need to find out the diamiter of the rod inside the 405 servo?
cheers.
Pug_101
cheers.
Keep searching, found this thread with good info on Rod sizes.
MC's
