adammada33
Wing Removal Tip Undamaged
adammada33
A common questions on here seems to be, How do I remove a wing and How do I remove a wing without damaging it. The wing is glued on with hard bostic glue/sealent I have done 6 now and have found a great techneque which leaves them undamaged.
You need an electric jig saw (battery or plug in) and a hacksaw blade (as fine tooth pitch as possable to lower cutting force and best quality you can get as they are stronger which helps)and a grinding wheel
Grind one end of the blade till it fits in your jig saw then lock it in
This can then be used to cut away 95% of the sealant it might break once or twice but just regrind.
I tried all the other methods like hot knife but if you have the kit this seems best to me.
Hope this helps
Adam
pugpete1108
Hope this helps
Adam
i little too late for me , i have just decimated two wings cos i got the hump with the sealant and just ripped them off :wacko: o well on needed replacing anyhow, good tip tho should remember that one
adammada33
The first ones I did ended up a mess even though I spent hours this method was learnt through hours of frustration
