GlasgowRob 0 Posted June 13, 2006 as above anyone ever experiences this before just had tuner out at my non starting 205 everything spot on spark timing etc but not fuelling, reckons sever blockage of fuel rail any gen? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted June 13, 2006 Are the injectors firing? If not have you tried a different tachymetric relay? If the fuel rail is getting fuel OK but its not firing its possible that the injectors aren't doing there job & this can often becaused by a dead tachymetris relay. I can't see the fuel rail being blocked, if it is then whatever has caused the blockage has managed to get through the filter & block a 6mm (or larger) pipe. Graham. Share this post Link to post Share on other sites
Butler 0 Posted June 13, 2006 Does the fuel pump prime? Share this post Link to post Share on other sites
GlasgowRob 0 Posted June 13, 2006 Does the fuel pump prime? fuel pump primes fine guys Share this post Link to post Share on other sites
Rob_the_Sparky 10 Posted June 13, 2006 Possibly a bust ECU? Did he actually check that there was fuel rail pressure or that the injectors were firing? I've never heard of a blocked fuel rail and it does seem stunningly unlikely. Rob Share this post Link to post Share on other sites
