stealth_pug 0 Posted June 13, 2006 hi, a friend of mine has a 306 which has not been used for a few months so the battery went flat. After charging the battery it still will not start. All of the obvious things have been checked like spark plugs etc... it is fitted with an immobiliser so could that have caused a problem when the battery went flat? kev Share this post Link to post Share on other sites
johnnie 0 Posted June 15, 2006 Yes kev 97% its the immobilizer which probably needs a reset.. The rest 3% I will give it to the distributor. Share this post Link to post Share on other sites
Guest smokinslim Posted June 15, 2006 Starter motor, corroded earth cable or loom connections? Share this post Link to post Share on other sites
jim205GTI 3 Posted June 16, 2006 Yes kev 97% its the immobilizer which probably needs a reset..The rest 3% I will give it to the distributor. i didn't think there was a dizzy system used on engines in the 306................or is there and ijust haven't seen mmm Share this post Link to post Share on other sites
