Baz 421 Posted June 9, 2006 I plan on doing an oil change at the weekend and thought that i might aswel replace the sump gasket unless it appears to be really sound, and thought it to be good practise to replace the washer for the oil temperature sender as i suspect it to be weeping a little! Can anyone tell me what I.D. the washer is, and is it a copper or fibre type? Also might be handy to know the ID of the plug washer for future reference if anyone knows off hand?? Cheers!! Share this post Link to post Share on other sites
sorr 0 Posted June 9, 2006 The washer for the sensor is the same as the washer for the sump ptwo sump plug. So just get 2 sump plug washers. Share this post Link to post Share on other sites
MartinM 0 Posted June 9, 2006 ...and if the sump gasket ain't broke, don't fix it! Share this post Link to post Share on other sites
Baz 421 Posted June 9, 2006 Ah Thanks for that! 2bh was only going to be doing the sump gasket if there was a weep from that but to be honest i think it's from the sensor spreading around, so won't bother! Share this post Link to post Share on other sites
inferno 1 Posted June 9, 2006 are you sure the senser itself hasnt broke down? i get to see a lot of moters, although admitidly ford and vw that break down and start to leek... Share this post Link to post Share on other sites
KRISKARRERA 2 1 Cars Posted June 9, 2006 ...and if the sump gasket ain't broke, don't fix it! Exactly! More bloody grief than it's worth unless it's badly leaking. Share this post Link to post Share on other sites
Baz 421 Posted June 9, 2006 Ya I kno!!! i know that from all posts about it Kris!! I'm pretty sure it's fine really. senser?? moter??? What is this??? Share this post Link to post Share on other sites
