Guest s.odedra
Lowering 1.9
Guest s.odedra
i just got a 1.9 want to lower it
would like it seating just above the tyre about 10 mm of the wheel :blush:
just like to know wot drop people have done... and wot set of spring (kit) was used.....
:o pics would be very helpful ;)
Alastairh
Heres mine roughly 30 - 35mm. Also running a 309 beam at the rear.
Alastair
j_turnell
Heres mine, very similar to Al's lowered -35mm on Avo coilovers with 309 beam running Koni adjustable dampers dropped one spline. Handles very very well :D
Edited by j_turnell
tom_m
its on coilovers so i'm buggered if i know how low it is! :blush:
jayblack-gti
Had mine lowered 35mm all round with koni adjustable dampers. handles very well and the setups only about £325 from larkspeed.co.uk
DaveK
so erm, 35 mm is best then? :blush:
Guest s.odedra
hummmm
cheers guys
35mm sounds good
but the other thing i forget to say was that i've got the 16" 206GTi NIMROD's on the car with 205/45/16s
gonna change the tyre too 195s as i'm having trouble on the bac with with 205s
any1 with else with 16s?
keith
i've got 16's with 40mm drop, personally, i wouldnt reccomend it. 35 seems to be that wee bitty better :wacko:
sonofsam
Here's mine lowered 30mm on Koni adjustables and 16" wheels
scotthall39
Personnaly i wouldn't go any lower than -40mm as it will destroy the handling as for the rear tyres rubbing, best way would be to fit the 309 rear beam and would vastly improve the handling. :lol:
Give me a shout if your interested in a beam :o
