309PUG
Dta
309PUG
Hi,
Can anyone help with a map for an 8v on TB's with hot'ish cam and 11.5:1 CR would be appreciated.
Chris
stew205
Can't help with an 8v map but have a standard 16v map if you need a starter :blush:
MartinM
Hi,
Chris
10 BTDC at cranking and idle rising to 20 BTDC at 2500rpm...
...then drive to a rolling road at no more than 2500 rpm and get it mapped properly.
You're highly unlikely to get an optimum igition map (ie across all rpm at different loads [ie MAP or TPS]) for your engine and ancilliaries from someone else.....
309PUG
Thanks for the advice guys.
Chris
