Ant
No Dash Board Lights
Ant
Since putting my 205 ---> 2.0 turbo loom in, the dash lights ( ie what illuminate the dash when the lights are on ) has stopped working. Ive tracked it down to wire 37a. If i put a +ve to that, all works. Wire 37a goes off into the main dash.. Before i start pulling the pug dash apart, can anyone advise where it terminates, so i can check the connection at that end.
M@tt
hi
i think you'll find wire 37a is actually to do with the indicators so i'm not sure why thats making the lights come on.
What should happen is when you you turn the lights on the stalk wire number 55 from the indicator stalks becomes live and thus make the lights on the car come on and also the illumination within the car instruments.
Wire 55 runs from the stalks into the fuseboard into connector R on pin 7 and comes out again of the fuseboard at:
Connector J pin 3 (wires 26 a & 26B)
Connector T Pin 1 (wire 25a)
Connector M Pin 1 (wire 55b)
so check with a multimeter that your getting +12v on any of those when the lights are switched on
It runs through fuse 13 for the inteior lights so check that that hasn't blown.
EDIT:: when you say you've replaced the loom does this include the lighting loom as well?? if so what vehicle is it out of because the numbers aren'ty going to be the same(but i can't see why you'd shange the lighting loom tbh)
Edited by M@tt
