Guest toby7
Remove Sunroof
Guest toby7
I am going to remove my sunroof and it leaks, whistles and would rathre do without it completely.
If I remove the sunroof glass, rails and framing (ie everything) leaving a big rectangle hole in the roof . . and urethane (strong silicone) a large thin tinted or clear piece of plastic or perspex in place . . . .will the roof be as strong as it was ? Is the existing sunroof framing there to provide a measure of structural ridgidity ?
Or would I be better off riviting a sheet of panel steel over the top.
Your thoughts please
DaveK
a sheet of steel would look alot better i reckon if you painted it to match the car. i would have thought perspex would work fine aswell tho, cant see the glass serving anything other thank letting the sun in
dave
24seven
Bought my 1.6 GTi with a panel riveted over the sunroof spot. could have had a better job done tbh. It would look better if it was welded in and smoothed off. also there are grooves where the rails were going down the roof, but unless you're looking virtually right at it, it doesn't stand out.
Guest toby7
I've booked my 205 in to have a panel steel sheet 'rolled' with a slight curve in it and 'bonded' to the roof to cover the sunroof hole.
The panel shop owner tells me he can do it in such a way that it would look very close to a non sunroof model.
Next up . . tinted perspex rear screen.
Pete
johnrobertgordon
Did mine a few weeks ago, just purchaced a sheet of ally and bonded it onto the roof. I finished it off with some rivets just to make sure. From some angles you would never know it was there!
Edited by johnrobertgordon
yorkdave
i pop riveted a plate from my mates old written off 1.9, just used plenty of seam sealent and some pop rivets, i think it adds to the rally slag look. there is a fair bit of dust in the seam, but i reckon it looks ok.
de Noir
Very ugly job, this sunroof "removal" of yours, guys. :)
Edited by MH_
DaveK
if you get this done toby post up some pics please :)
Depends how you use your car, i think most of the guys have done this with a view to motorsport use, in which case the cars are no good looking too pretty anyhow.
pdd144c
Just do this:
Pugnut
Just do this:
that cardboard will only last until it rains! :)
now wheres my gaffer tape!
@toby, if you're bloke could make up a few of these he would sell them like hotcakes on here . i for one would definately be interested.
Al
johnrobertgordon
Very ugly job, this sunroof "removal" of yours, guys. ;)
May look ugly but it got me my logbook! :D
