Guest Tom Dimma
Brakes
Guest Tom Dimma
after having a 309 rear beam put on i have no rear brakes ive been told by the garage its the master cylinder but does anyone else have any ideas?
thanks
Tom
What are the symptoms?
Have you bled the brakes properly to expel all the air?
Graham.
Guest Tom Dimma
i gave it to a garage and he assures me the brakes are bled but he couldnt get any fluid out of the rear brakes.
More likely siezed compensators than the MC if the front brakes are still OK....
Not quite sure how the brakes can be bled properly if no fluid came out of the rear circuit. :)
Is it a 1.6 or 1.9 GTi originally? Compensators are the most likely suspect like Anthony says though.
Graham.
Guest Tom Dimma
its a 1.4 atm hoping for an engine transplant soon. so the compensators are they easy to do or would you recomend getting a garage to do it?
Simes
Easy to do, in theory but remember they are over 10 years old. I assume on a 1.4 the compensator will be under the bonnet.
AFAIK a 1.4 has the compensators built into the rear wheel cylinders so it might be something more serious thats stopping fluid getting through.
Have you fitted the disc brakes on the 309 beam?
Graham.
Guest Tom Dimma
no ive still got the drums on the rear could it be something as simple as a brake line has been bent or damaged so the fluid isnt getting through?
Thats a possibility but there should be two brake lines to the rear so both must be blocked.
Graham.
Guest Tom Dimma
yeah i will check these when i get my car back from the body shop. thanks will let you know the outcome
Thanks again
