Edp
307 Brakes
Edp
Today ive fitted my long overdue 307 brake conversion. Im using the new calipers,discs,pads and new front braided hoses i made today.
Ive now come to the bleeding process and bled just the fronts first of all, i drove the car slowly up the drive and nothing happened!!
The pedal went directly to the floor.
I have now bled both the fronts and rears but its basically the same. What have i done wrong???
Ed
TEKNOPUG
3 possibilites:
1.) You have a fluid leak
2.) You have an air leak
3.) You're MC is shagged (this can happen quite easily when bleeding brakes with an old MC as the rubber washer things get damaged or moved).
Edp
hmmm well the MC is only about 8 months old. Theres no fluid leak as ive checked that. I guess there could be an air leak as even with the engine off the pedal never goes stiff.
When bleeding does the cap need to be on or off?
I'm using one of these one way valve things, i might have to ask my dad to pump the brakes....
GLPoomobile
I tried bleeding my brakes for the first time the other weekend. Was using an £8 'easybleed' type of thing from Halfords, with the one way valve at the end. Bloody thing was s*ite and was letting air back in the system. Went through about 3 bottles of fluid trying to bleed it. In the end I drove down to my mate the morning after and we bled it the old fasioned way. Took about 10 minutes and easy as pee. Think I'll just do it the old fasioned way with two people in future.
Edp
Thats what I wanted to hear :blush:
I will let you know on my progress, theres to many unfinished threads which is crap for people using the search.
Rippthrough
Go get a gunson eazybleed. Makes it all a 30 second job.
Or get a spare reseviour cap and epoxy a tyre valve into it, does the same job, plus you can keep a bit of pressure in should you wish.
returnofjim
Yep i use one of those and there very good, except on one 205 i used it on it wouldnt seal on the mc expansion tank so we had to do that one the old fashioned way :blush:
Guest Cartooner
Yep, the Gunson Easybleed makes bleeding a laugh. Never had more fun whilst bleeding :)
Edp
Did the two man effort tonight with a mate and its all fine. Bled the brakes through and took her for a test drive. I cant believe what a difference these brakes are going to make.
The braking is already about as good as my old ones were, so once these babys have worn in it should stop on a 6 pence.
TEKNOPUG
I've got a Gunson as well but could never get it to seal properly on the old 205 reservoirs. You can use a more modern 306/406 reservoir with the 205 MC's which seal much better. I'll try that when I change the MC shortly.
Simes
That's what I want to hear as mine should be on in about 2 weeks. What's the pedal travel like on a standard 1.9 M/C?
Edp
Well for me the pedal goes down about a quarter of the way and starts braking. The pedal dosent go down as far as I thought it would. I think they will be superb once bedded in though.
Ed
tom_m
like ed says pedal travel only slightly longer than standard. don't even think of swapping for the 23mm mc, it leaves you with zero pedal travel and bugger all modualtion!
Simes
Cheers Tom,
M/C ordered, discs arrived today...my god they are huge and well thick!!
off to Pug tomorrow to get the rest.
To add the discs are now £19.88 + VAT from Brake part, the price quoted in the guide on the main site is £24.75 so they've gone down in price.
Edited by Simes
Guest Cartooner
I mounted 307 Hdi discs and calipers today, but must say honestly that the pedal travel is too much for me :) , I'm definately going for a bigger HRC. :)
jim205GTI
mmm i found them just right for me when i swopped mine over ....had to swop the mc but that was for same size...... going to be interesting to see how they stop once the mi is in :)
