c_r_thomson
How To Move Piston In Caliper?
c_r_thomson
Hi Guys whats the best things to use to push the piston back into the caliper when fitting new brake pads?
Tried levering it with a screwdriver but it is solid and won't budge. The brake pads i removed were really worn and almost down to the metal!
Any advice/tips are most welcome :wacko:
Ta, Craig
inferno
i normally use a large set of pipe grips, but if its the rears normally they wind in with a large screw driver.
pj838
Yes mate the rear pistons screw in using the grooves on them. Don't try hitting em like I did once upon a time! :)
c_r_thomson
Sorry, shoud've said! It's the front pads i'm replacing
205mattgti
I used brut force and pushed the piston back in
if u have Bendix calipers check to make sure the carrier pistons r not siezed as i have just done mine and found one of the front carrier pistons to be stuck
lub it all up before u put it back to gether
done mine now all ok, go through the windscreen now if u slam the brakes on
lol
hope this helps
matt
Guest rick03054
One of these does a pretty good job
G-clamp
You can loosen the bleed nipple & then push them back by hand, I can on mine even without doing the bleed nipple.
Graham.
