kate205gti 4 Posted May 30, 2006 does anyone know the best place to get vernier pulleys from please? after some mi16 ones for next month cheers Share this post Link to post Share on other sites
charlie_sav 0 Posted May 31, 2006 The catcam ones are very good, very quick to get accurate adjustments, moving the pin between each hole is 1 degree of adjustment, and the the colour does not wear off that quick compaired to other makes, www.Catcams.co.uk Share this post Link to post Share on other sites
kate205gti 4 Posted May 31, 2006 i couldnt see a price on there charlie how much are they please? Share this post Link to post Share on other sites
Anthony 1,003 Posted May 31, 2006 Apparently the DW8 vernier pulleys are a straight swap onto an Mi. Certainly less elegant than the Catcam ones and don't have the pin, but they're significantly cheaper than all the aftermarket ones. I spoke to Peugeot today and got a price for the DW8 pulleys: 080590 - DW8 outer cam pulley - £21.01 080591 - DW8 inner cam pulley - £19.26 080639 - DW8 cam pulley bolts - £0.26 each (£0.78 for 3) That makes the total price £41.05 + VAT per pulley, less any discounts Share this post Link to post Share on other sites
jacobs53 0 Posted May 31, 2006 Apparently the DW8 vernier pulleys are a straight swap onto an Mi. Certainly less elegant than the Catcam ones and don't have the pin, but they're significantly cheaper than all the aftermarket ones. I spoke to Peugeot today and got a price for the DW8 pulleys: 080590 - DW8 outer cam pulley - £21.01 080591 - DW8 inner cam pulley - £19.26 080639 - DW8 cam pulley bolts - £0.26 each (£0.78 for 3) That makes the total price £41.05 + VAT per pulley, less any discounts There's 8 of these engines sitting in college doing nothing!!!! I think they might be a little pissed if a steal them all lee Share this post Link to post Share on other sites
charlie_sav 0 Posted May 31, 2006 (edited) I think they are about £170 plus the vat but would have to check with matt, but the pug ones are alot cheaper but no bling !! LOL. Edited May 31, 2006 by charlie_sav Share this post Link to post Share on other sites
Guest ashnicholls Posted June 6, 2006 Can the peugeot ones be machined easily to fit the 8v easily? Share this post Link to post Share on other sites
B1ack_Mi16 67 Posted June 6, 2006 (edited) Just get some offset-ground cam sprocket keys from petert. I found that so much easier to use, so my brand new Catcam pulleys will just be lying on my desk for a very long time Much easier to set the timing after cambeltchange and such when using std. pulleys with offset-keys. Combination of 4deg keys and (2) and (3) pulleys will give a wide spread of adjustment. 107, 110, 111, 114, 115, 118 deg lobecentres. Can't see that you would ever need to set the cams at more than 118 or much less than 107 degrees Edited June 6, 2006 by B1ack_Mi16 Share this post Link to post Share on other sites
kate205gti 4 Posted June 12, 2006 these sound interesting! what are they and how easily can they be timed please?? (and if not that easy how much would u sell the verniers for lol! ) Share this post Link to post Share on other sites
