John_B
Ignition Amp Wiring
John_B
My Mi wont start and I've found a thin green wire loose from the ignition amp connector. It's connected to number 4 on the connector.
Anyone know where it's supposed to go? Is it an earth?
jonand
My Mi wont start either :blush: , and the amp connections on mine are:
pin1 to coil pin 2
pin 2 to earth (green/yellow - M)
pin 3 no connection
pin 4 switched +ve (brown - 2B)
pin 5 + 6 to ecu pin 1 (green - 101)
I've no reason to doubt these as it started previously :P
Hope it helps
Jon
mbayley77
There is a picture on the main website on the carb guide which shows the wires and where they belong.
John_B
Thanks for the tips. taffycrook sorted it in 2 min. It was actually a live connection though I'm not sure which one.
jonand my 4th pin is def green. Pug don't make it easy do they.
