aeinstein
Mi16 Dying
aeinstein
i did a quick search and couldn't find a similar tale.
i've promised my pal with his mi16 i'd ask the advice of the most likely source of an answer...
so, here goes. he pulled it out of the garage after a few months off the road, and it wouldn't start, low fuel etc, so added £5 of total 97 super, and it ran fine about 20 miles, then he filled it with optimax, to the brim, got about a mile, and it cut out. :) it felt like electrical imo, cos it didn't splutter, it just stopped.
he waited 5 mins, and it started ok and ran sweetly for a few miles and then stopped again. this happened all the way back. when it dies, its not on full throttle, but shortly after usually, (coincidence?)
today it conked out and wouldn't restart, and as he was turning the engine, it smelt of petrol through the exhaust.
he thinks its the optimax, but i don't see it, as he syphoned it out and put it in his mates 20v fiat, which ran fine this aft, and his mi now has 97 in again.
its a 80k engine which was rebuilt 2k ago, and usually runs ok. the only other thing its suffered with is ticking over high sporadically, which i believe was a missing screw in the tb butterfly, and is now fettled.
has anyone else suffered like this? and how was it sorted? he is puzzled, as am i. :D
thanks in advance,
al
PsychoSimon
tell him to check the connections around things like the coil and the ignition amplifier. mine runs an 8v coil and every now and again it used to just die, and it turned out to be a dodgy connection at the coil.
Tell him to also try around the crank position sensor. these are only three things other than the ecu that have anything to do with the ignition - and my guess is it's the ignition that is the problem because it is giving it enough fuel to make it smell through the exhaust.
Hope this helps,
Regards,
Simon
Guest Cartooner
Since it has been stored for a while I'd search in the fuel delivery. Pressure regulator? Fuelpump?
I've had those exact symptoms and it was the crank sensor
aeinstein
cheers for that, its ace that its possible to use everyones combined knowledge to keep our cars going.
and boy is that a vital resource when we drive 205s! :D
i'll let you know what it turns out to be
al
taffycrook
Check for sticking AFM.
If you smell fuel and you have a spark its not CAS.
Plus if it happens after you give it some beans my guess is AFM sticking in a high engine load position making it overfuel to the point of cutting out.
Martin W
How would you cure this, sounds like a problem I have??
Martin
