Guest Tidybri
Clutch Cable
Guest Tidybri
Hi All well i finaly managed to get a picture to explain here it is the clutch cable apears on the left and the odd piece of metal i talk about is on the left. When i was tightening the cable this piece of metal fell out and the pedal; sat on the floor. i could not tell where it came from but when i put it here it made the pedal stay high again i have attached both pics 1 with and 1 without
Any ideas?
http://www.maxiboy.co.uk/test/front.jpg
http://www.maxiboy.co.uk/test/front2.jpg
Adam B
Its just like a link pin thing that sits there and transfers the force from the clutch arm to the thrust bearing release arm.
Not actually held in by anything but by the springy-ness of the clutch plate.
Better put it back in to make it work... ;)
Thats exactly whre it goes, without it there you won't have a clutch.
Guest Tidybri
yeah i have put it back and tightened the cable now the clutch sits v high. Higher than both the break and accelerator. Does this mean i need a new cable because if its much looser the car still moves forward when in gear.
I have got it quite tight i spose i can losen it a bit but the biteing point is quite low not sure wot my next move is??
The clutch pedal should sit slightly higher than the brake & accelerator but not by that much, adjust the cable so it sits about 1/2" higher & if the biting point is midway through the pedal travel its fine. If its on the floor your clutch is in need of replacment imo.
Guest Tidybri
Thats wot i was afraid of Graham how much you think that should cost me then?
I hope not a small fortune my m8 said he would fit me a new 1 for £120 if i get a clutch or £180 if he gets it is that a good price?
inferno
the price of the clutch seems about right... labour depends on where u take it... that doesnt look like mates rates though! took me 4 hours to fit my gti6box with a new clutch too, when i blew my 1.9 box up
Guest Tidybri
How much would you do it for? im a complete novice when it comes to all this! so any help gettin wot is becoming a pain in the arse car on the road with minimum cost is apreciated! I also think im going to have the rear beam looked at at some point 2.
Unfortunatly my budget might not cope with this car for much longer so its gonna be of the road for a while at this rate i find another problem everytime i fix 1............
Grim.Badger
It just cost me £300 for a clutch, but I had the flywheel skimmed plus a new crankshaft seal, plus a new input shaft seal and a bit of engine oil for that price. It was originally quoted at £235 for just the clutch.
One company did quote me for £400 but I think that was a special "Young lad with a GTi" quote ;)
Guest Quakes
Dunno if there is one near you but ive always used Mr Clutch http://www.mrclutch.com/ always done it the day i phoned usually ready 4 hours after you drop it off and for the bargain price of £160 all in (clutch and labour) he even fixed my exhaust and door lock without telling me :( no problems with there clutches either seem very good
Guest Tidybri
Just called Mr Clutch £174 fitted not bad!!
Thanks mate
