westy 0 Posted May 17, 2006 Hey, I've bought myself a little project for the summer, and one of the fist things to do it get the fuel guage working. I suspect its just the connector thats ome off - Where is it located? is it easy to get to? Thanks! Share this post Link to post Share on other sites
jonD6B 0 Posted May 17, 2006 It's under a large round black grommet in the floor pan above the fuel tank next to the fuel pump iirc. Share this post Link to post Share on other sites
westy 0 Posted May 18, 2006 It's under a large round black grommet in the floor pan above the fuel tank next to the fuel pump iirc. Sorry, i meant on the dashboard end Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 18, 2006 Connection to the clocks is under the insturment cowl, if the fuel guage has stopped working have you checked the fuses as I'd be surprised if the connection has come off the clocks & thats all that isn't working. (I think it should be pin #5 on the white plug, possibley a blue wire). Graham. Share this post Link to post Share on other sites
westy 0 Posted May 18, 2006 Connection to the clocks is under the insturment cowl, if the fuel guage has stopped working have you checked the fuses as I'd be surprised if the connection has come off the clocks & thats all that isn't working. (I think it should be pin #5 on the white plug, possibley a blue wire). Graham. Any ideas which fuse it would be? Share this post Link to post Share on other sites
pug_ham 245 3 Cars Posted May 19, 2006 Result of trying a . :( Graham. Share this post Link to post Share on other sites
westy 0 Posted May 19, 2006 Result of trying a . :( Graham. shocking stuff well, considering that everything else works apart from that, it could be the other end? Share this post Link to post Share on other sites
